Tim Porter-Devriese Posted May 10 Share Posted May 10 Hello, A few questions related to drawing a brick mill building. First, I want to use one fill for the brick in plan, but a different fill in the cross section cut. I've selected my section viewport and changed the brick wall fill to the hatch that I want, which is what I see recommended in the forum, but it doesn't change anything for me. These are untstyled walls with a class fill for brick. Next, I have one wall that appears almost totally transparent. Class, layer, fill, and opacity all appear to be identical to adjacent brick walls that appear correctly. Finally, this is more of a long shot. The walls get one brick wythe thinner each floor you go up, so I drew a separate wall for each layer. Now of course there are horizontal lines between the walls of different layers. I know there's a stacked wall tool, but that would require me to do a lot of placing of window and door openings, so I'm hoping there's another way to eliminate the lines between different wall levels such. Thanks in advance to anyone who might be able to help. Quote Link to comment
Tom W. Posted May 10 Share Posted May 10 39 minutes ago, Tim Porter-Devriese said: Hello, A few questions related to drawing a brick mill building. First, I want to use one fill for the brick in plan, but a different fill in the cross section cut. I've selected my section viewport and changed the brick wall fill to the hatch that I want, which is what I see recommended in the forum, but it doesn't change anything for me. These are untstyled walls with a class fill for brick. Next, I have one wall that appears almost totally transparent. Class, layer, fill, and opacity all appear to be identical to adjacent brick walls that appear correctly. Finally, this is more of a long shot. The walls get one brick wythe thinner each floor you go up, so I drew a separate wall for each layer. Now of course there are horizontal lines between the walls of different layers. I know there's a stacked wall tool, but that would require me to do a lot of placing of window and door openings, so I'm hoping there's another way to eliminate the lines between different wall levels such. Thanks in advance to anyone who might be able to help. This is all quite easy to remedy but be easier to demonstrate with a sample file if you can post one. Quote Link to comment
Tim Porter-Devriese Posted May 10 Author Share Posted May 10 Tom - I got it. I am 14 hours in on my project today and making dumb mistakes. I thought that certain things were set to class attributes but as you probably know, they were not. Thank you for offering to look at my file. 1 Quote Link to comment
Tom W. Posted May 10 Share Posted May 10 Cool. Data Vis is another way to change the appearance of objects in VPs if needed. 1 Quote Link to comment
