Vectorworks SDK 2025
NikitaA
We were using VWs 2021 to utilize SDK and connect to a web application through Vectorscripts. Now, we have moved to version 2025 and one urgent issue is coming up. Can somebody help.
We take a snapshot of drawing without text around it and it used to work fine in 2021 version. Now that we have moved to 2025, it is taking a screenshot of the drawing along with the text around.
Can somebody please help. I am not sure if commands has changed or what is happening.
I am using the following:
def ClipWhitespaceFromImage(self, inImageFilename):
        try:
            image=Image.open(inImageFilename)
            image.load()
            bg = Image.new(image.mode, image.size, image.getpixel((0,0)))
            diff = ImageChops.difference(image, bg)
            diff = ImageChops.add(diff, diff, 2.0, -100)
            bbox = diff.getbbox()
            if bbox:
                new_image = image.crop(bbox)
                new_image.save(inImageFilename)
            logging.debug("Saved clipped image to " + inImageFilename)
        except:
            logging.debug("!!!Exception: In ClipWhitespaceFromImage: " + traceback.format_exc())
        return inImageFilename
    def MakeWhitePixelsNonOpaque(self, inImageFilename):
        try:
            start_color = (255, 255, 255, 255) # white
            new_color = (255, 255, 255, 0) # black
            img = Image.open(inImageFilename).convert("RGBA")
            shape_data = numpy.array(img)
            # Replace start color with new color
            shape_data[(shape_data == start_color).all(axis = -1)] = new_color
            # Convert back to image
            final_image = Image.fromarray(shape_data, mode='RGBA')
            final_image.save(inImageFilename, "PNG")
            logging.debug("Saved opacity image to " + inImageFilename)
        except:
            logging.debug("!!!Exception: In MakeWhitePixelsNonOpaque: " + traceback.format_exc())
  • 5 weeks later...
