Bas Vellekoop Posted May 6, 2025 Share Posted May 6, 2025 Hi all, I tought this existed already, but could not find it. Is there a Marionette script that puts all symbols in a grid on your design layer? Quote Link to comment
Pat Stanford Posted May 6, 2025 Share Posted May 6, 2025 I think this is the one you are thinking of. But there are other older and less powerfu versions also: Quote Link to comment
Pat Stanford Posted May 6, 2025 Share Posted May 6, 2025 The search term I used to find these was "place all symbols" and then for the last one (because I knew I wrote it but it did not show "placeallsymbols" 1 Quote Link to comment
Marionette Maven Marissa Farrell Posted May 7, 2025 Marionette Maven Share Posted May 7, 2025 @Bas Vellekoop There's also this from @DomC, not in a traditional vwx format as the file is missing, but might be what you were thinking of? 1 Quote Link to comment
Bas Vellekoop Posted May 8, 2025 Author Share Posted May 8, 2025 @Pat Stanford Thanks for all the search results! @Marissa Farrell This node / marionette script is was looking for. Is there a way of getting it back? Quote Link to comment
Marionette Maven Marissa Farrell Posted May 8, 2025 Marionette Maven Share Posted May 8, 2025 For a while I was able to get to an old hosting of the techboard, but it no longer seems to work. I'll try to track down if there's anyone who knows if we can still get to things internally, but otherwise I can throw something new together for you soon. 2 Quote Link to comment
DomC Posted May 11, 2025 Share Posted May 11, 2025 Hi You may search for this one? 1 Quote Link to comment
Bas Vellekoop Posted May 12, 2025 Author Share Posted May 12, 2025 Whoopwhoop 🎊 Indeed going to test this soon. Quote Link to comment
Nico_be Posted June 12, 2025 Share Posted June 12, 2025 Hello, I've been using this script for a long time, and I've integrated it into the menu via the Plugin Manager because it's so practical and frequently used. PROCEDURE ShowAllSymbols; {?1999 Graphsoft, Inc.} {The traverseSymbolList procedure was developed by Craig Hollinshead.} VAR numFolders, numNestedFolders, numSymbols : INTEGER; messageString : STRING; OK : BOOLEAN; NewPtSize : INTEGER; OldPtSize : INTEGER; SelectedObj : HANDLE; TheSymbolName : STRING; SymFolderName : STRING; TheSymDef : HANDLE; SymDef2 : HANDLE; ChangeAllLines : BOOLEAN; CurrLayer : HANDLE; X, Y : REAL; XSpacing, YSpacing : REAL; NumAcross : INTEGER; StartX, StartY : REAL; LayerNames : ARRAY[0..200] OF STRING; Index : INTEGER; {=============================================================================} PROCEDURE TraverseSymbol(theSym:Handle); VAR symObjClass : STRING; origLineWt : INTEGER; symName : STRING; symInstance : HANDLE; sX1, sX2, sY1, sY2 : REAL; BEGIN symName := GetSDName(theSym); symName := GetName(theSym); Symbol(symName, X, Y, 0); symInstance := LNewObj; GetBBox(symInstance, sX1, sY1, sX2, sY2); TextFace([bold]); TextOrigin(sX1, sY2 - 1); BeginText; symName EndText; numSymbols := numSymbols + 1; {Increment symbol count here for accurate tracking} X := X + XSpacing; IF (X >= (StartX + (NumAcross * XSpacing))) THEN BEGIN X := StartX; Y := Y - YSpacing; {Move to next row} END; Message(concat('The Sym#', Num2Str(0, numSymbols), ' is - ', symName)); END; {PROCEDURE TraverseSymbol} {==============================================================} PROCEDURE traverseSymbolList (itemHdl:HANDLE); BEGIN WHILE (itemHdl <> NIL) DO BEGIN CASE GetType (itemHdl) OF 16:BEGIN TraverseSymbol(itemHdl); END; 92:BEGIN SymFolderName := GetName(itemHdl); numFolders := numFolders + 1; numNestedFolders := numNestedFolders + 1; LayerNames[numFolders] := SymFolderName; Layer(SymFolderName); X := StartX; Y := StartY; TraverseSymbolList (FInFolder (itemHdl)); END; END; {CASE GetType (itemHdl)} itemHdl := NextObj (itemHdl); END; {WHILE (itemHdl <> NIL)} IF numNestedFolders > 0 THEN numNestedFolders := numNestedFolders - 1; END; {PROCEDURE traverseSymbolList} {==============================================================} BEGIN {*/// Main program ///*} XSpacing := DistDialog('Enter Horizontal Spacing Distance:', ''); YSpacing := DistDialog('Enter Vertical Spacing Distance:', ''); NumAcross := IntDialog('Enter the number of symbols per row', ''); Message('Click on top left corner of the grid'); GetPt(StartX, StartY); CurrLayer := ActLayer; numFolders := 0; numNestedFolders := 0; numSymbols := 0; X := StartX; Y := StartY; LayerNames[0] := GetLName(ActLayer); IF FSymDef <> NIL THEN TraverseSymbolList (FSymDef); Index := 0; Layer(LayerNames[Index]); WHILE (FInLayer(ActLayer) = NIL) DO BEGIN Index := Index + 1; Layer(LayerNames[Index]); END; SetLayerOptions(1); Redraw; ClrMessage; END; {PROCEDURE ShowAllSymbols} RUN (ShowAllSymbols); Quote Link to comment
