Paolo Posted May 30, 2002 Share Posted May 30, 2002 Is it possible to dinamically change a custom object menu displaying all available classes in the document? The goal is to have specific plugin elements with classes choosen from the standard document list (not style-1, style-2, style-n prepared in the usual way in plugin parameters editor).I've tried to set the list in the menu at object creation (IsNewCustomObject), but when I attempt to change menu parameter values with SetRField (in a FOR cycle passing a class string at each loop), the result is the insertion of only the last value passed, not the entire list. I fear this is not possible as I have never seen, till now, a plugin with such behaviour, but I'll be glad to be contradicted. Quote Link to comment
Fuge Posted May 30, 2002 Share Posted May 30, 2002 Paolo, If I understand you correctly. You can changethe classes attached to different object withina PIO. I don't quite understand how your trying to do it. Sorry I can't be more helpful. Dave Quote Link to comment
Alexandre Villares Posted May 30, 2002 Share Posted May 30, 2002 That is a very good question indeed! If I uderstand it correctly: Is it possible to change the value-list of a PIO pop-up parameter from inside it? Note: To chage a parameter's value is easy, what Paolo wants is to change the options that will appear on the pop-up at the Obj. Info Palette... rgds,Alexandre Quote Link to comment
Paolo Posted May 31, 2002 Author Share Posted May 31, 2002 quote: Originally posted by Alexandre B A Villares: That is a very good question indeed!If I uderstand it correctly: Is it possible to change the value-list of a PIO pop-up parameter from inside it? Note: To chage a parameter's value is easy, what Paolo wants is to change the options that will appear on the pop-up at the Obj. Info Palette... rgds,Alexandre -Yes, it is so, let's have, for example, a parametric chair in which legs material have a pop-up menu class where we may choice from one of the classes available on the drawing. ciao,Paolo Quote Link to comment
