Fuge Posted March 23, 2002 Share Posted March 23, 2002 You can write something to print multiple layers or sheets within the active document, BUT you have to be willing to hit the "OK" button everytime the print dialog appears, which is really not very desirable. You cannot print mulitple files however,or batch files to save them as DWG files. It would be nice to see vectorscript reachoutside the active document and allowscriptors to suppress print and other dialogs.Something like what Filemaker does would be a step in the right direction. If your intent is to print drawings within adocument, let me know more exact what you what to do, I'll be glad to help you out. Dave Quote Link to comment
DWHarper Posted March 23, 2002 Author Share Posted March 23, 2002 Is it possible to write a script that will batch print a number of drawings? Or for that matter, batch convert a number of drawings to .dwg format? that's what I send to my architect. This would be a big time saver for me. If it is possible, I would be willing to learn Vectorscript.....the learning curve would be worth it! Dave Harper PE Quote Link to comment
Petri Sakkinen Posted April 3, 2002 Share Posted April 3, 2002 On the Mac you can select all the files and say 'Print'. If you have something like OkeyDokey Pro, it can click 'OK' for you. Dunno about Windows, but surely something similar exists. Inside the document you will be able to run a script that calls all (or specifically defined) Saved Sheets, then says Print. Again, you need outside help to click OK. There was recently a discussion about the topic on the VectorScript mailing list. You might check the archives. VWA has a Print Sheets command, which also links to the Issue Manager. Quote Link to comment
Alexandre Villares Posted April 4, 2002 Share Posted April 4, 2002 Please note that there is no such thing as a VectorScript-List archive. [uPDATE: Now there are VS-L archives at http://lists.nemetschek.net/archives/vectorscript-l.html ] [ 02-16-2004, 12:32 PM: Message edited by: Alexandre B A Villares ] Quote Link to comment
Petri Sakkinen Posted April 5, 2002 Share Posted April 5, 2002 Really? Hmm - I have 2750 messages (starting from Feb 1999) in my file and one of its advantages is that I have filtered my own postings so the average usefulness of the messages is higher than that of the complete archive... Quote Link to comment
Stuart Child Posted February 13, 2004 Share Posted February 13, 2004 Has there been any progress with this in the new editions of Vectorworks (10 and above)? This would speed up drawing issues no end. Quote Link to comment
ccroft Posted February 14, 2004 Share Posted February 14, 2004 Alex http://lists.nemetschek.net/archives/vectorscript-l.html It doesn't go back quite as far as Petri's but it's quite useful. Charles Quote Link to comment
Alexandre Villares Posted February 16, 2004 Share Posted February 16, 2004 Thanks Charles! When I posted that in 2002 there was no list archive... I campaigned for it?s creation! thanks anyway, A [ 02-16-2004, 12:30 PM: Message edited by: Alexandre B A Villares ] Quote Link to comment
