htranbos Posted April 11 Share Posted April 11 Hello, I am trying to write a small python script to rename selected cameras in the active document. However, I cannot find any function reference for Camera. Does anyone know where it is? Thanks! Quote Link to comment
Jesse Cogswell Posted April 11 Share Posted April 11 There aren't any dedicated functions for Camera objects that I know of, but you wouldn't need anything specific to cameras for what you are asking. If you just want to rename the camera, you can use vs.SetRField to change the Camera's internal record field to the name you desire. The Camera object also seems to have its unique name automatically update from that field, so it wouldn't be the worst idea to also use vs.SetName to set the object to the new name. And you would also need a vs.ResetObject to get the changes to stick. Here's a sample script that changes a selected camera's name to "new name". Keeping in mind that there's no sort of error checking to make sure the name is not already in use or verifying that the selected object is actually a Renderworks Camera. If you need help in how to flesh this out to fully meet your needs, let me know. import vs h = vs.FSActLayer() name = "new name" vs.SetRField(h,"RenderWorks Camera","Name",name) vs.SetName(h,name) vs.ResetObject(h) Quote Link to comment
Jesse Cogswell Posted April 11 Share Posted April 11 Actually, playing around with this a little more has revealed that the internal record field for "Name" and the object's name are linked, so changing either of them will update the other. This means that if you change both of them, like I do in the script above, will result in a "-1" being added since the name is then otherwise in use. If I were in your shoes, I think I would just use the SetName function and be done with it. 1 Quote Link to comment
