LDJMiller
Calling Fields in Spotlight
I am working on a plug in that, in, part, calls upon the parameters of the lighting device and light position objects in spotlight.
When I call:
SelectObj(('Light Position Obj'.'Position Name' = Destination));
I can select objects that have been created since the creation of the plug-in, but it returns NIL for any position that was created before the plug-in, even if there are search criteria that match.
Any thoughts on why?
Thanks in advance,
Jason
I tried the same thing and it worked on objectscreated before the script was first ran.
I don't know how your setting the "Position" field, but if you were to type Destination with an accidental space before or after it your vectorscript won't select that object.
Just a thought...Good Luck
Fuge
