Sir_Dan_Fortesque
Placing an object in a drawing before end of PIO
Hello,
Can someone help me with the following problem.
I have a PIO (Plug In Object) which draws a rectangle on the drawing. The rectangle appears in the drawing AFTER the end of the PIO. This is a problem for me because I have to attach a record on the rectangle during execution of the PIO.
How can I draw my rectangle during the execution of the PIO?
I will appreciate your help very much and I wish you a very nice day.
Friendly greetings,
StarGate
Hello Everyone,
Yesterday I posted this problem. In the meantime I found the solution. You will find the code below this text.
First create a record called recTest. Then create 2 fields called width and height. Then create a PIO or a Vectorscript and past the code below. You are ready to run now.
The code draws a rectangle and connect record recTest to it. Also it fills the fields with some example values.
Hope you find some use for it. Have a nice day.
Friendly greetings,
StarGate
procedure Test; var hndLayer:handle; hndObject:handle; hndRecord:handle; LntPosX:longint; LntPosY:longint; BEGIN { Start main program } hndLayer := ActLayer; hndRecord := GetObject('recTest'); GetVCenter(LntPosX,LntPosY); SetRField(hndRecord,'recTest','width','150'); SetRField(hndRecord,'recTest','height','250'); rect(LntPosX-100,LntPosY-100,LntPosX+100,LntPosY+100); hndObject := LnewObj; { This code does the trick } SetRecord(hndObject,'recTest'); END; { End of script Test } run(Test);
