no offset in Vectorscript??
  • 1 year later...
I've used this offset polytool. It only allows offset by point mode. It is very frustrating!!!! I had to design my own offset tool which was pretty tricky and time consuming.
Good Luck.
quote:
Hi Dfortin,
What do you mean by 'point mode' ?
Isn't the function dist . mode based?
Would you be willing to sell your code ?
(I have many VW9.5 clients and some of my new tools might need the VS10 offsetpoly call).
PS: I wish the VW offset tool would produce a polyline...
Basically OffsetPoly offsets polygons from their original location to a user defined distance in the X direction.
This is not what were looking for we need a true offset tool.
PS. Alexander I would like to sell you my code. The only problem is that I think that I would be fired for it.
  • 3 months later...
  • 3 months later...
Yes I have used this in a script .What a misnomer it should be called X axis duplicate function .I hope they really do provide a real offset function soon . I thought this was the whole idea of scripts to do what You can manually into a scripted form . Come on NNA crank it up a bit .
Never realized the offset was missing, but I never found the Trim and Extend functions, and at the end develop my own Trim procedure.
Offset a poly (plygon and polyline) on a vs work relatively well with a bit of trigo on the vertex:
Say a (x,y) vertex, a,b the angles from/to the two adjacent vertex and ofs my offset value the simplify formula looks close to:
Xnew:=x+( ofs*(Cos (a)+Cos (-b)) );
Ynew:=y+( ofs*(Sin (a)+Sin (-b)) );
The open ends need a modif but the general idea is the same.
The angles need a good control: they can change the side for the offset, and should be in radiants for the trigo funtions.
I use a similar formula (but on 3D) to work on nurbs, but the first study was done on polys.
This is a good starting point for an offset tool and was a first idea that I had as well. The problem with this aproach is that each line of the newly offset polygon will not be parallel with it's original counterpart.
ie. If you draw a polygon with many obtuse and acute angles and use the graphical offset tool to offset the poly one inch, you will see that each vertex is not always exactly one inch from the original. If you move them to one inch it distorts the shape of the new polygon.
The path you need to go down is to copy the polygon, convert it to lines, figure out the angle of each line, use the cosine and sine rules to figure out where to move the center of that line, then move all the lines to there location, and finally join them all together. The tricky part is knowing what is the inside of the polygon and what is the outside. The offset tool that I have developed is for polygons only because I have no way of determining what side of the poly line to offset to.
Good luck!
I think this is the point of it all .I have spent a number of hours working this problem to .It would save much if this was a workable function or at least an accessible DomenutextByName.
Its not helping all of us scratching around doing our own thing with code no-one really wants to share .
Sorry, I can not give the full develop formula.
But, here goes one of the first offset procedures I did when I start to torture nurbs.
He only work with 3 vertex (2 sides) polygons and polylines: up to you to clean up my mess and work with arrays to increase the n? of vertex.
He will fist ask you to click on the poly to offset, then on the side you want the offset and finally the value.
AlexandreBA Villares... where is the check?
code:
Procedure Offset;
VAR
x,y,x1,y1,x2,y2,xs,ys,a,b,c,e,off: REAL;
d,t: INTEGER;
h,h1,h2,h3: HANDLE;
o,u: BOOLEAN;
p1,p2,p3,p4:POINT;
BEGIN;
GetPt(x,y);
h:=PickObject(x,y);
t:=GetType(h);
Message (t);
GetPolylineVertex(h,1,x,y,d,a);
GetPolylineVertex(h,2,x1,y1,d,a);
GetPolylineVertex(h,3,x2,y2,d,a);
GetPtL(x,y,xs,ys);
MoveTo(x,y);
LineTo(x1,y1);
h1:=LNewObj;
a:=HAngle(h1);
MoveTo(x1,y1);
LineTo(x2,y2);
h2:=LNewObj;
b:=HAngle(h2);
MoveTo(x,y);
LineTo(xs,ys);
h:=LNewObj;
c:=HAngle(h);
e:=90;
IF c<a Then e:=-90;
DelObject(h1);
DelObject(h2);
DelObject(h);
off:=RealDialog('OffsetValue','0');
p1.x:=x+( off* Cos(Deg2Rad(a+e)) );
p1.y:=y+( off* Sin(Deg2Rad(a+e)) );
p2.x:=x1+( off* Cos(Deg2Rad(a+e)) );
p2.y:=y1+( off* Sin(Deg2Rad(a+e)) );
p3.x:=x1+( off* Cos(Deg2Rad(b+e)) );
p3.y:=y1+( off* Sin(Deg2Rad(b+e)) );
p4.x:=x2+( off* Cos(Deg2Rad(b+e)) );
p4.y:=y2+( off* Sin(Deg2Rad(b+e)) );
LineLineIntersection(p1,p2,p3,p4,o,u,p2);
IF t=5 Then Smooth(0);
IF t=21 Then Smooth(1);
BeginPoly;
AddPoint(p1.x,p1.y);
AddPoint(p2.x,p2.y);
AddPoint(p4.x,p4.y);
EndPoly;
END;
Run (Offset);
[/code]
Here my own Poly Offset studies, it works on n-sided closed polygons and I think it solves the inside/outside problem (this code draws some offset locus on the outside of the selected polygon):
code:
 Procedure PolyOff;
VAR
pHd : HANDLE;
i, n, Vtype : INTEGER;
D, A, Vradius : REAL;
M :VECTOR;
C, V0,V1, V1A, V1B, V2, VF :POINT;
B1, B2 : BOOLEAN;
BEGIN
{*} pHd:=LSActLayer;
{*} IF pHd <>NIL THEN BEGIN
D:=RealDialog('Offset Dist.','1');
n := getVertNum(pHd);
FOR i:=1 to n do BEGIN
IF i=1 THEN BEGIN
GetPolylineVertex(pHd, n, V0.x, V0.y, Vtype,Vradius);
GetPolylineVertex(pHd, i, V1.x, V1.y, Vtype,Vradius);
GetPolylineVertex(pHd, i+1, V2.x, V2.y, Vtype,Vradius);
END ELSE IF i<n THEN BEGIN
GetPolylineVertex(pHd, i-1, V0.x, V0.y, Vtype,Vradius);
END ELSE BEGIN
GetPolylineVertex(pHd, 1, V2.x, V2.y, Vtype,Vradius);
END;
MoveTo (V0.x, V0.y);
LineTo (V1.x, V1.y);
HCenter(LNewObj,C.x,C.y);
A:=HAngle(LNewObj);
DelObject(LNewObj);
M:=Ang2Vec(A+90,0.001);
IF PtInPoly(C.x+M.x,C.y+M.y,pHd)
THEN M:=Ang2Vec(A-90,D)
ELSE M:=Ang2Vec(A+90,D);
V0.x:=V0.x+M.x; V0.y:=V0.y+M.y;
V1A.x:=V1.x+M.x; V1A.y:=V1.y+M.y;
LineTo (V2.x, V2.y);
A:=HAngle(LNewObj);
DelObject(LNewObj);
V1B.x:=V1.x+M.x; V1B.y:=V1.y+M.y;
V2.x:=V2.x+M.x; V2.y:=V2.y+M.y;
LineLineIntersection(V0,V1A,V1B,V2, B1,B2, VF);
Locus(VF.x,VF.y);
END; {of FOR}
{*} END;
END; run(PolyOff);
[/code]
PS: Kiwi, I've sent you a private msg! [Wink]
[ 10-09-2003, 09:52 PM: Message edited by: Alexandre B A Villares ]
  • 2 weeks later...
  • 1 month later...
