geometry accuracy set too high
Hi @Peter Telleman
This error normally displays when there is an error in the truss symbol geometry.
The issue is in the custom FD33 T corner. I'm not sure what the actual cause of the error is but when the 'center Line is turned on in the corners properties it isn't displaying correctly, you can compare it to the default library point up FD33 T version.
To fix the issues use the right click customise truss symbol data command and in the dialogue hit the edit magnets command, this resets the magnets and corrects how the center line displays. make sure to update the custom library as well otherwise this issue will come back everytime you use it.
