Flair-Studio Posted March 15, 2025 Share Posted March 15, 2025 Is there a way to export the content of a keynote legent to a worksheet (and then to excel) without having to save the notes into a database? THank you Quote Link to comment
1 Pat Stanford Posted March 17, 2025 Share Posted March 17, 2025 Easiest is probably to make a VW Worksheet of the Calouts and then export that to Excel. For the most basic 2 column Legend (Identifier and Text) the functions would be something like: Create a database row of Type is Callout. In the first column header enter a formula of ='Callout'.'Keynote Idenitfier' In the second column header enter a formula of ='Callout'.'Text' You may have to manually type the Callout.text formula rather than use the formula builder. Ask again and post a sample if you need more help. 2 Quote Link to comment
0 Flair-Studio Posted March 17, 2025 Author Share Posted March 17, 2025 @Pat Stanford sorry what is the fastest way to export the content of a keynote legend please? Should I save all the entries in a one-off (project based) database? Is there an alternative like a script? Many thanks Quote Link to comment
0 Flair-Studio Posted March 17, 2025 Author Share Posted March 17, 2025 (edited) 2 hours ago, Pat Stanford said: Easiest is probably to make a VW Worksheet of the Calouts and then export that to Excel. For the most basic 2 column Legend (Identifier and Text) the functions would be something like: Create a database row of Type is Callout. In the first column header enter a formula of ='Callout'.'Keynote Idenitfier' In the second column header enter a formula of ='Callout'.'Text' You may have to manually type the Callout.text formula rather than use the formula builder. Ask again and post a sample if you need more help. It woeked beautifully by adding formulas as per the above, rather than using the builder. Thanks again for all your precious help! Sorry one last question: if there are multipe keynote legends in a file, how do you set the criteria to chose just one? I tried to assign the legend to a different class but it didn't work. Edited March 17, 2025 by Flair-Studio Quote Link to comment
0 markdd Posted March 17, 2025 Share Posted March 17, 2025 Why not add Selection State - Is Selected to the search criteria? Quote Link to comment
0 Pat Stanford Posted March 17, 2025 Share Posted March 17, 2025 As @markdd suggested use a Selected criteria. Or if they are on different layers, specify the layer. Or give the legend a Name in the OIP and use the Name criteria. Or Class. Or attach a record and use the presence of the record or a field value in the record. Or set the fill or line color and use that or ..... 😉 2 Quote Link to comment
Flair-Studio
THank you
5 answers to this question
