  • 1
Data Vis is applying texture inconsistently
line-weight
See attached VW file.
I have a data vis that is supposed to apply a texture to objects that match my criteria.
It is applying the texture to these two wall objects, but it seems to be doing so at a different scale on one face of one of them. As far as I can see there is no difference in the two objects that explains this.
Am I doing something wrong or is VW?
DV text override.vwx
2 answers to this question
15 minutes ago, Tom W. said:
Right-click on the render component in the OIP + select 'Reset to Default Mapping'. That corrected it for me.
Ah - thank you. That did it.
Looks like I am going to have to go through a number of wall objects in my original file (where I extracted the example from) and do this for each one individually. But at least I can sort it.
