Interior elevation not showing full height
Hello-
I used the View > Create Interior Elevation Viewport.
3 of the walls came through perfectly - One of the walls, see attached, 'Kitchen Cabinets' are only displaying partial height in this viewport.
The same view direction from a different location in the room 'Kitchen Wall' shows the entire wall with cabinetry
At some point the whole wall was visible and I was able to add dimensions for the cabinetry
This 'block' persists when I go from this Interior Elevation to 'Elevation in Place', however, it is not there when I'm viewing the whole house model
Any thoughts or ideas what may be causing this?
Elevation not showing full height.pdf
2 hours ago, taliho said:
Hello-
Hi @taliho,
While I'm not sure what caused it to be created that way, you should be able to fix it by:
  1. Selecting the interior elevation viewport.
  2. Click on the "Advanced Properties…" button in the Object Info palette.
  3. In the Extend tab of the Advanced Properties dialog, adjust the End Height as needed.
