File size reduction PDF sets for email attachment
Todd
I'm sending a PDF set as an email attachment - it's over the maximum file size. Is there a simple way to reduce the file size (Top plan 2D graphics) without noticeably compromising the image quality?
Thanks
Edited by Todd
21 answers to this question
Thanks
The only way I know is to reduce sheet layer DPI + republish. Or publish as image. For PDFs containing raster geometry you can easily compress using iLovePDF etc but for Top/Plan (vector) that doesn't work. I don't really understand why VW generates so such PDFs from 2D graphics- it's crazy. Hopefully someone else knows better.
I ♥️ PDF web site: free, great compression—generally better IMO than Adobe's. and their other products on the same page are also awesome. PDF convert to Excel is my second most used feature there.
I should perhaps point out that a multipage PDF is compressible for free, but multiple files at once are not.
Edited by mjm
clarity
I use iLovePDF too but as per my posts above it only works on raster geometry + the OP specifically referred to Top/Plan 2D graphics. I even spoke to iLovePDF about this directly the first time it happened + they said there was nothing they could do to compress my PDF.
6 hours ago, Peter Neufeld. said:
Hello,
What happens when you try the different options in the Export to PDF dialogue?
Cheers,
Peter
Likewise these settings only affect image based geometry.
2 hours ago, bcd said:
Apple's Preview>Save As>Quartz Filter>Reduce File Size
I have a PDF generated from VW - a map - that looks like this:
It is 26.5MB. When I save it with Quartz Filter set to 'Reduce File Size' the resultant PDF is 39.8MB in size 🙂
I wonder if it's rasterizing vector hatches?
If you run it a second time what's the result?
I get same results w/ the Apple Quartz filter.
Are there raster images (.jpgs, or .png etc) in your drawing?
I'm using VW 2018 (but this has been an issue in vw since I started in 2004)  where an image file extends beyond the viewport, that all of the image data is exported/pubished to the pdf - this does not seem to be a thing regarding vector data. So I split images into tiles and put each tile in its own class  - it's a really slow kludge, but sometimes necessary.
It is the nature of some compression algorithms to result in a file becoming larger - sometimes. VW is very inneficient with its handling of hatches, and with stipples it is even worse.
Regarding the sample file @Tom W. sent me.  Neither PDF Expert nor PDF Tollkit+ could compress the file.  I'm attaching a screenshot of the PDF Toolkit message indicating the problem with vector graphics.  I then exported the PDF to a PNG to get rid of the vector graphics, created a PDF back from the PNG, and then compressed.  This worked with Preview, PDF Expert, and PDF Toolkit+.  Not the greatest option if you have a lot of sheets.
Based on this, I think that when possible it would be better to replace vector (and hatch) heavy underlays like maps with a rasterized PNG or JPG when feasible, keeping the vector data only in the portions that are needed.
Edited by E|FA
  • Like 3
Thanks for your research @E|FA
Appreciate you looking at it @E|FA thank you. Yes, this is essentially the same thing that iLovePDF told me when it first happened to me several years ago. It is definitely a problem with how VW deals with vectors. Publishing as image is an option, it's just you lose definition doing this. The other option is to publish as PDF but lower the resolution, however go too far + Hatches start to go wonky. What's annoying is that I have similar maps to the one I sent you which were produced by others (in other software) + they are <1MB yet identical in terms of detail/quality...
I think I read somewhere that over time VW has optimised 3D performance at the expense of 2D so not sure if this is an example of that. My experience is that I can have a 2.5GB+ file crammed full of 3D geometry + performance is perfect until I try to zoom in on a complex Hatch + then VW starts stuttering... But perhaps that would improve if I upgraded my computer?
