Split lines with arc
setdesigner
8 answers to this question
Thanks all for theses suggections. My case was a general simple exemple, the reality is a bit different and more complex.
All your solutions made me learn new tricks
With the clip tool, it works well fo a circle (or arc) but if I have a polyline or an oval as the clipping shape, I can't figure how it could work.
The convert to polygon method is good but I loose the smoothness since the polygon is a series of straight lines. For this case it is absolutly fine, I am just thinkng about other situations.
And the duplicate along path method is very good too, just not applicable in my case now but I will keep it in mind.
Many thanks for you support
It works with a Polyline as well, you'd just need to redraw the Arc rather than convert it
You could also do this using Modify - Trim, which would even work with keeping the Arc object as an Arc or even use something like an oval in the middle.
Oval inside field of lines
Select all objects
Run Modify - Trim and be careful just to click on the Oval object.
Result
Use Alt + marquee selection to select all interior lines
Edited by Jesse Cogswell
  • Like 3
