Alpha channel images not transparent
Hey folks,
I have been creating some images in the visualizer and check the Alpha Channel box.  The image(s) created look like they have a transparent background  but as soon as they get inserted into the drawing, the background goes solid white.  Anything that I'm missing here?!
Hello @salukitd if you are using the create bitmap object button the bitmap object should have fill set to None and the alpha channel set.  If you are saving to file then re-importing, make sure on import to choose PNG and alpha channel and set fill on the bitmap object to None so it draws with alpha instead of opaque.
