3D Polygon Extrude Issue
Cory W.
3D polylines can be "extruded" using the Push/Pull tool as long as the geometry is planar. Without digging into the geometry too deeply, I suspect that the Red Polygons are not quite Planar, hence the problem you see here.
Try converting them to NURBS Surfaces using the Create Surface from Curves command and then have another try. You should have better luck.
Edited by markdd
Wow! You guys are great!
On 2/2/2025 at 3:02 PM, Jonathan Pickup said:
3D Polygons should not be able to be extruded. Did you know there are several 3D red polygons?
Btw Jonathan (and others), I have zero idea how that red polygon has multiple copies. No doubt, user error. Thanks for pointing it out, though.
Edited by Cory W.
