Paolo Posted January 31 Share Posted January 31 Mouldings Plugins is a set of PIO and tools to manage trim and woodwork. See this post, here in the forum, containing some fine renderings courtesy of @cberg and @Greg G In this update: Added Hollow Stainless Steel sections (imperial and metric standards) profiles. Added WindsorONE profiles. Now the profiles amount to approximately 7200! Library dialog enhanced: • Profiles's thumbnails shows both imperial and metric sizes. • Profiles's thumbnails are visibly improved (especially in VW2025). • Search field added. • Last used… and Preferred… added to the tree list. Search / Replace menu: you can search / replace the profiles used in all moulding objects on the drawing according to what you set in the replace dialog. Browse document profiles (button) now opens with the last used profile. Frames Array: now you can set styles and rails thickness to 0 to repeat only the frame. Fixed some forbidden char in folder/files naming. Other bug fixing and interface improving. Mouldings Plugins update is free for registered users, and available through Gumroad® or Payhip® at 25€ It is also available a free demo version where most of the plugins parameters are disabled. You can unlock it at any time buying a license key through the above mentioned Gumroad® or Payhip® markets. 4 Quote Link to comment
Andy Broomell Posted January 31 Share Posted January 31 The new Search / Replace command is fantastic! Thanks Paolo! 3 Quote Link to comment
