mikeakar Posted January 29 Share Posted January 29 Below I have a curved counter (in yellow) that will need curved tubular supports. I would like to create a path to then extrude my geometry along the path. I tried to compose these lines to create a continuous line for my path, however they do not join. How do I go about this? The black lines are curved polylines, following the geometry of the counter, the red lines are lines perpendicular to the floor. Thank you! Quote Link to comment
Kevin Allen Posted January 29 Share Posted January 29 are those plain old lines, or did you use the poly line tool? Quote Link to comment
mikeakar Posted January 29 Author Share Posted January 29 2 minutes ago, Kevin Allen said: are those plain old lines, or did you use the poly line tool? red are lines, black is polyline, because of the curve Quote Link to comment
VIRTUALENVIRONS Posted January 29 Share Posted January 29 I think you have to post the file please 1 Quote Link to comment
mikeakar Posted January 29 Author Share Posted January 29 3 minutes ago, VIRTUALENVIRONS said: I think you have to post the file please TY Counter Example.vwx Quote Link to comment
Kevin Allen Posted January 29 Share Posted January 29 3 minutes ago, mikeakar said: red are lines, black is polyline, because of the curve I do not see any curves, only straight line? Quote Link to comment
VIRTUALENVIRONS Posted January 29 Share Posted January 29 Is this what you are looking for. Quote Link to comment
Kevin Allen Posted January 29 Share Posted January 29 I don't think the lines are properly aligned. Once aligned, they need to be converted to NURBS and then composed. Then you can extrude along the path. Quote Link to comment
VIRTUALENVIRONS Posted January 29 Share Posted January 29 @Kevin Allen I looks like the curves were made from 2D curves so I did the conversion to NURBS and joined an offset point. The clean curve is enclosed.COUNTER CURVE.vwx 1 Quote Link to comment
mikeakar Posted January 29 Author Share Posted January 29 8 minutes ago, VIRTUALENVIRONS said: @Kevin Allen I looks like the curves were made from 2D curves so I did the conversion to NURBS and joined an offset point. The clean curve is enclosed.COUNTER CURVE.vwx that is what I am looking for, thank you! Quote Link to comment
VIRTUALENVIRONS Posted January 30 Share Posted January 30 (edited) @mikeakar There were a couple of things that were problematic.. All lines, curves, etc. need to be connected. Below are two screen shots of the offending geometry, but after I corrected that, compose still would not work. Try it and see what happens for an explanation. I converted all your polylines to NURBS curves (Convert to NURBS) and then "Compose". It worked as it should. Polylines are primarily a 2D tool. They don't convert well to other geometry. Edited January 30 by VIRTUALENVIRONS 1 Quote Link to comment
