Claudia D. Posted January 24 Share Posted January 24 Hello I would like to automate the display of information as text (by importing a script in txt Format, that ist writen in another program, where the Data is stored/managed). The text should appear where the "UserOrigin" point was defined in the Sheet-Layer (not Designlayer - that works ans is easy). I would like to call the commands with a script that first queries the "UserOrigin" point (it depends on the file) and then places the corresponding text there. I already do this for Design-Layers. However in the Sheet-Layer it does not work for me because I cannot access the "UserOrigin" point. Instead the text is placed at the VectorOrigin point in the Sheet-Layer. So how can I access the UserOrigin point of the current Sheet-Layer? Thanks for your support. Best regards Claudia Quote Link to comment
Claudia D. Posted January 24 Author Share Posted January 24 My actual "Workaround" looks lke this: PROCEDURE LoadFile; VAR xOriginString, yOriginString, TestText, HName:STRING; isSheetLayer:BOOLEAN; xOrigin, yOrigin:REAL; tempHandle, textHandle, H:HANDLE; BEGIN; {$DEBUG} H:= FLayer; {Handle to active Layer} HName := GetLName(H); while (H<>nil) do begin if GetSheetLayerUserOrigin(H, xOrigin, yOrigin) then xoriginString:= Num2Str(6, xOrigin); yoriginString:= Num2Str(6, yOrigin); TestText:= Concat('Here is the Origin in Layer: ', GetLName(H), ', x = ', xOriginString, ', y = ', yOriginString); H := NextObj(H); HName := GetLName(H); end; FillPat(0); FillFore(0,0,0); FillBack(65535,65535,65535); PenBack(65535,65535,65535); TextFont(GetFontID('Arial')); TextSize(12); TextFace([]); TextFlip(0); TextRotate(0); TextSpace(2); TextJust(1); TextVerticalAlign(1); TextOrigin(xOrigin, yOrigin); BeginText; TestText EndText; tempHandle := LNewObj; SetPenFore(tempHandle,65535,0,0 ); END; Run(LoadFile); Quote Link to comment
Pat Stanford Posted January 24 Share Posted January 24 The "User Origin" does not apply to sheet layers. About the best you could do would be to put your text on a separate design layer and make that layer visible in your Viewports on the sheet layer. Quote Link to comment
Pat Stanford Posted January 24 Share Posted January 24 I was incorrect. There is a User Origin for each sheet layer. But it is probably not the same as the User Origin that is shared between the design layers. You can access this in a script using the following function: FUNCTION GetSheetLayerUserOrigin ( layerHandle :HANDLE; VAR xOrigin :REAL; VAR yOrigin :REAL ) :BOOLEAN ; Quote Link to comment
Claudia D. Posted January 31 Author Share Posted January 31 On 1/24/2025 at 6:29 PM, Pat Stanford said: FUNCTION GetSheetLayerUserOrigin ( layerHandle :HANDLE; VAR xOrigin :REAL; VAR yOrigin :REAL ) :BOOLEAN ; Hi Pat Thank you for your answer. When I apply the function GetSheetLayerUserOrigin, I get an x and y value for the design layer at the top position even if I am currently in the sheet layer. Hence my workaround above. That is the reason why I iterate through all layers and get the x and y values from the sheet layer. Otherwise I always end up in the design layers. The workaround works. It's just a bit much script for manoeuvrable output. Not such a nice solution. Best regards Claudia Quote Link to comment
Pat Stanford Posted February 2 Share Posted February 2 GetOriginInDocumentUnits and GetSheetLayerUserOrigin both seem to work correctly. Does this script do what you want? Procedure TagAtSLUserOrigin; {©2025 Pat Stanford - pat@coviana.com} {licensed under the Boost Software License 1.0} {https://github.com/boostorg/boost/blob/master/LICENSE_1_0.txt} {TL/DR Use as you want, attribution for source, No warranty} VAR H1, H2 ,H3 :HANDLE; X1,Y1, UPI, MLS, DLOX, DLOY :REAL; B1 :Boolean; BEGIN GetOriginInDocUnits(DLOX, DLOY); {moving onbjects on Sheet Layers requries an offset from the Document User Origin} H1:=FLayer; {Get first layer in document to process all} H2:=ActLayer; {store active layer to reset at end of script} While H1<> Nil DO BEGIN If GetObjectVariableInt(H1, 154)=2 then {ObjVar 154 is Layer Type 1= DL, 2=SlabThickness} BEGIN Layer(GetLName(H1)); {makes the SL Active Layer} B1:=GetSheetLayerUserOrigin(H1, X1,Y1); MoveTo(X1-DLOX, Y1-DLOY); {move to the SL Origin - DL Origin} CreateText( Concat('The SL UO is: ', X1, ' ', Y1) ); End; H1:=NextLayer(H1); End; Layer(GetLName(H2)); {Restore the active layer at the beginning of the script} End; Run(TagAtSLUserOrigin); Quote Link to comment
Claudia D. Posted February 7 Author Share Posted February 7 On 1/31/2025 at 9:05 AM, Claudia D. said: Hi Pat This works perfectly. Thanks. I will replace my workaround by your script. Best, Claudia Quote Link to comment
