Sam Williams Posted January 22 Share Posted January 22 Hi, I have the problem that with tail connectors which may flip upside down i can use the flip command to rectify normal instances of the connector label being upside down. However, where i have a network switch with all outbound 1G Ports on the right and 10G Ports on the left. When connecting switches with 10G ports, one will always be upside down due regardless of flipstate. Also when using network devices, where Lan ports are on the left side of the device the connections show correctly. However, when using Lan ports on the right side of the device. (where we use the right side of the network switch) one side is always upside down. I cant always show a Lan connection on the left hand side - Primarily on system input endpoints as the Lan port is actually an output. How do i fix this? (Don't say put the connector on the left side of the device)...Please Quote Link to comment
Pat Stanford Posted January 22 Share Posted January 22 Do you have Adjust Flipped Text turned on in Document Preferences? Quote Link to comment
Vectorworks, Inc Employee Conrad Preen Posted January 23 Vectorworks, Inc Employee Share Posted January 23 @Sam Williams a picture would help if you have the time. Quote Link to comment
