Hybrid Symbol
Daniel Cortes VWX
I’m experiencing an issue after upgrading to V2025. I created a custom stage deck with 3D geometry, which works perfectly, and I can rotate it by 45 degrees without any problems. However, after adding a 2D component, I can no longer rotate it due to the layer plane constraints. What could be causing this issue? I've done this multiple times in V2023 without any problems. Is this a result of the V2025 update?
4 answers to this question
This looks like normal behavior.
If you have any geometry in both the 2D and 3D spaces, you have a hybrid symbol.
Once you create 2D geometry in the Top/Plan space of the symbol, VW won't let you rotate the Symbol out of plane with the Top 2D geometry.
  • Like 4
@Daniel Cortes VWXWhen you use a truss symbol or light symbol you place a truss object or a lighting device object and not just a simple symbol. Using the truss object and the lighting device object, and not just a simple symbol, is what allow you to rotate the geometry.
