Chris Noel Posted January 17 Share Posted January 17 Are surface hatches able to be affected by Data Visualizations? I'm mostly looking to change their colors, but Data Visualizations only seem to change the "cut" pens and not those beyond or before the cut plan of a section viewports, elevation viewports, or horizontal section viewports. I know the objects in particular I'm looking to effect are selected because I set the criteria to something that would only select them and it has the correct count in the window. Quote Link to comment
Tom W. Posted January 17 Share Posted January 17 3 hours ago, Chris Noel said: Are surface hatches able to be affected by Data Visualizations? Yes they are but it is done by changing the texture that's applied to the object. So you will need to create a Hatch Fill with the colour/s you want + apply it to a texture then select that texture in the Data Vis Display Criteria. Quote Link to comment
Chris Noel Posted January 17 Author Share Posted January 17 Okay -- that's unfortunate. I was hoping Data Visualization would be a way to avoid having to make tons of duplicates of hatches and textures just to have different colors based on views or phasing. Thanks anyways! Quote Link to comment
