Symbol - which is the source file?
Sztamgast
2 answers to this question
If you hover your mouse over the referenced symbol listing in the Resource Manager, a popup modal will appear, showing you the Name of the Resource, it's Resource type, and it's referenced source file name.
If you select a referenced symbol in the design layer, then in the Object Information Palette, there will be a "Source:" field, which will give you the referenced file name as well.
Edited by markdd
Thanks, Markdd. Solved.
In the Resource Manager that didn't happen; I had tried this first. However, now, miraculously, it does work.
In the Object Info palette: that works.
