Wood Posted January 14, 2025 Share Posted January 14, 2025 Hi Folks, Looking to curate my saved set resource and arrange the collapsable lists, etc. I've found the XML file that appears to hold the data, but modifications there don't seem to change the VW dialog. How can I manage this data? Thanks! Quote Link to comment
stayathomedad Posted January 15, 2025 Share Posted January 15, 2025 (edited) The load data file for distributed loads and for point loads are both called LoadData.xml In Mac OSX they are located in [user]>Library>Application Support>VectorWorks>2024[or whatever version you are using]>Plug-ins>VW_Spotlight>Data>Braceworks. You should see two folders here - PresetDistLoads & PresetPointLoads. The LoadData.xml files are located in the corresponding folder. I use a general text editor and when I make changes to the xml file. No restarting of the program or reloading of the drawing should be needed. I can see those changes right away. Edited January 15, 2025 by stayathomedad Quote Link to comment
Wood Posted January 21, 2025 Author Share Posted January 21, 2025 Thanks @stayathomedad I figured out the Syntax for the lists, if anybody else is wondering: <WeightData isTotal="false" legend="" loadGroup="Cable" name="4 12/14 Socapex 2.24" ressourceName="12/14 Socapex" weight="2.24 lb/ft"/> 'WeightData isTotal=' False makes the makes your weight by a distance, as specified in the 'weight=' command. True makes it the overall load. 'loadGroup' sets the dropdown category. You must use an existing category. 'name' is the title of the individual load entry 'ressourceName' is the subgroup category. You want this to be the same for every item you want in a dropdown menu. Also, if you're having trouble finding the library folder, OS X is kind enough to hide it from you. Go to your user folder, right click, Show View Options, Show Library Folder. Quote Link to comment
