GatRed Posted January 13 Share Posted January 13 (edited) Hi, We are thinking on using 2025, but I noticed that the room finishes of space are lost when I convert the file > see example attached. Is that normal ? or is it un bug that will be corrected ?Vectorworks-Space 2024.vwx @François de Felix? Edited January 13 by GatRed Quote Link to comment
0 Vectorworks, Inc Employee Kevin S Posted January 13 Vectorworks, Inc Employee Share Posted January 13 8 hours ago, GatRed said: Hi, We are thinking on using 2025, but I noticed that the room finishes of space are lost when I convert the file > see example attached. Is that normal ? or is it un bug that will be corrected ?Vectorworks-Space 2024.vwx @GatRed That is not the intended 2025 behavior. The reason it is happening is that the room finishes for the space in 2024 do not have a key assigned to them. That's what the empty [] means. If you assign the Space finish in 2024 to have a key abbreviation, it will transfer correctly into 2025 with the finish being assigned to the first position. I will file a bug for this and include the file you provided. Thanks for letting us know! Quote Link to comment
0 GatRed Posted January 14 Author Share Posted January 14 Thanks a lot @Kevin Shertz ! Quote Link to comment
GatRed
Hi,
Is that normal ? or is it un bug that will be corrected ?Vectorworks-Space 2024.vwx.thumb.png.96d244c0f8398979ec8f545ea9a4570d.png)
@François de Felix?
Edited by GatRedLink to comment
2 answers to this question
