Ree033456 Posted January 10, 2025 Share Posted January 10, 2025 Please help, I am learning how to render for the first time in Vectorworks and for some reason my model is rendering with lines like all the walls have outlines around them, I don't have draw edges on and I also have the line render options turned off, and I went through the classes and layers and found nothing? and It is only in this model, other models are rendering dine. does anyone know how I can fix this? Quote Link to comment
Pat Stanford Posted January 10, 2025 Share Posted January 10, 2025 Posting a screen shot or the file would help us understand what you are seeing and make it easier to recommend a solution. Quote Link to comment
Elite Exhibits Posted January 10, 2025 Share Posted January 10, 2025 @Ree033456Is the render Mode OpenGL/Shaded or RenderWorks ? Peter Quote Link to comment
Ree033456 Posted January 10, 2025 Author Share Posted January 10, 2025 This is the problem, it only shows in a render works style but its not there in shaded/OpenGL Quote Image Removed by user request Quote Link to comment
Elite Exhibits Posted January 10, 2025 Share Posted January 10, 2025 @Ree033456 This looks like two things at one time ? Either two Design Layers one wireframe on top of another that is Open GL / Shaded render ? or Some items are not filled ? Select an Item that looks like lines only - the green items in the upper portion of your image - Open the Attributes Palette - is there a Solid Fill ? See attached - Page 1 - Rendering is Open GL / Shaded Blue item has a solid fill - rendered solid. while the green items are pen only - Solid Fill.pdfrender as line. Page 2 - Rendering is Open GL / Shaded Green items now have a solid fill and render solid Peter Quote Link to comment
Ree033456 Posted January 10, 2025 Author Share Posted January 10, 2025 Yes! this is working but only for certain objects not everything? I will keep trying Thank you! Quote Link to comment
Elite Exhibits Posted January 10, 2025 Share Posted January 10, 2025 @Ree033456 A 3D object, such as an extrude, is directly selectable and the Attribute Palette shows the Fill & Pen A Symbol, on the other hand, may look (in the Attributes Palette) as thought the Fill & Pens as set correctly - yet one needs to Edit the Symbol then select a 3D component inside to know what the Attribute Palette settings actually are. see attached Peter Attributes inside a Symbol_01.mov Quote Link to comment
Ree033456 Posted January 13, 2025 Author Share Posted January 13, 2025 Yes! Thank you! I had to go back and edit each wall but it stopped generating outlines in the end :) Quote Link to comment
