Landartma Posted January 10, 2025 Share Posted January 10, 2025 I want to create a water feature for a client. I created the upper and lower water fall area as well as the site grading using 3d polys as site modifiers....site is flat so I have to do some heavy fakery to make it remotely believable. I'm not sure the best way to connect the stream with a stream bed and sides so it shows it flowing down hill with intermittent water falls. Whats the best tool/tools to use to create it? Its the highlighted object. Quote Link to comment
VIRTUALENVIRONS Posted January 14, 2025 Share Posted January 14, 2025 Hello, I saw this when you posted. I was working on something else, but was interested in seeing what the others came up with. I don't know where the usual suspects are on this one. Can you elaborate a little more and perhaps post some pictures similar to what you are wanting to do. Others should chime in when they see more detail. Quote Link to comment
Landartma Posted January 14, 2025 Author Share Posted January 14, 2025 I ended up just using 3d polys classed as SiteDTM modifiers and changed the individual verticies as needed. Its not perfect but I think it will give the client an idea of what I'm thinking. The site is flat so I started by grading a hill pretty far into the yard, updated the site model then used the 3d polys to make a swale. Then I took another set of 3d polys offset to create the benches and sent them to the surface of the site model. Once that was done I connected the individual vertices where needed to resolve the funky geometry. I created a hardscape and draped it over the ponds and stream. its the first time I tried it so It took a bunch of trial and error but I think I have a method. I think as I create them I will save them as symbols...I'm wondering if any of the pond manufactures have 3d cad ponds worked out. They have all their equipment as CAD details but I don't see anything like complete water features. I used Dynascape for a number of years and they had 2d pond layouts available. I guess you could use that line work to create 3d polys and create that way. I'm going to ask Aquascape what they have....I don't want to reinvent every time. 2 Quote Link to comment
