Jonk Posted January 2 Share Posted January 2 Hello and Happy New Year! I have a hardscape graphic legend that is pulling from my drawing and reporting back the area of each hardscape. It's working correctly but for the life of me I can't figure out how to get the comma separator in the area value? I'm using this worksheet function: #WS_AREA##sq ft_0_1# Is there something I need to add in there to get the comma separator to show up? See attached screenshot. Thank you! Quote Link to comment
Pat Stanford Posted January 2 Share Posted January 2 In VW2025, there should be a check box in the Advanced Function display to show the thousands separator. It appears to just add #thsep# to the end of the function. I did this on a Data Tag, but I think the Graphical Legend uses the same options. Quote Link to comment
Tom W. Posted January 2 Share Posted January 2 20 minutes ago, Pat Stanford said: I think the Graphical Legend uses the same options. I don't think it does unfortunately... Quote Link to comment
Jonk Posted January 2 Author Share Posted January 2 @Pat Stanford @Tom W. Yeah it doesn't use the same options unfortunately. I tried editing the definition including the #thsep# at the end and that didn't work either. Seems like there should be a way to achieve this. Quote Link to comment
Pat Stanford Posted January 2 Share Posted January 2 Sorry for misleading you. I can't make it work either. @Nikolay Zhelyazkov can you help with including a thousands separator in a graphical legend dynamic number field? 1 Quote Link to comment
Jonk Posted January 2 Author Share Posted January 2 18 minutes ago, Pat Stanford said: Sorry for misleading you. I can't make it work either. @Nikolay Zhelyazkov can you help with including a thousands separator in a graphical legend dynamic number field? No worries! Quote Link to comment
Vectorworks, Inc Employee Nikolay Zhelyazkov Posted January 6 Vectorworks, Inc Employee Share Posted January 6 Hello @Pat Stanford, @Jonk, Unfortunately the Graphic Legend is not using exactly the same parser as the data tag at the moment. I will log a but about this. Best Regards, Nikolay Zhelyazkov 1 Quote Link to comment
Jonk Posted January 7 Author Share Posted January 7 On 1/6/2025 at 3:52 AM, Nikolay Zhelyazkov said: Hello @Pat Stanford, @Jonk, Unfortunately the Graphic Legend is not using exactly the same parser as the data tag at the moment. I will log a but about this. Best Regards, Nikolay Zhelyazkov Thank You! Quote Link to comment
