Leonarddel Posted January 2 Share Posted January 2 How does the Distributor tool order these in the drop down list? And is there a way to have it in numerical order? Quote Link to comment
LiteDoctor Posted January 2 Share Posted January 2 The Outputs are ordered by their Stack Order on the 2D model. The Lower they are on the Stack, the Higher they will appear on that list. To manipulate it, Edit the 3D components of the Distro's Symbol. Select the Output lowest on Distro. The Menu Command is Modify>Send>Send to Back. (Shortcut on Mac is Command-B) Exit the Symbol Editor. That Output will now be the 1st one you see on the list. Now you can go back into the Symbol Editor and keep repeating that step for every output, starting from the bottom and working your way up (you don't have to save after every edit, I just put that in so you could see it in action.) For Distros that I have made, I put the Input at the top of the list. You decide what works for you. 2 Quote Link to comment
Leonarddel Posted January 2 Author Share Posted January 2 Fascinating, Easy fix thanks for that info. Quote Link to comment
