Preserving 3D locus comment field when converting to 3D stake Object
I have some 3D locus points the sixth field is a comment (in VW as cmt:). Entered the comments manually into my GPS and then converted the gpx points to .shp in QGIS, and amazingly VW was able to read that.
What I want to do is have queue just pop up a label that contains the relevant comment for each of my 3D locus points. I understand that with VW 3D locus point functionality is crippled (or nonexistent) and I have to convert to a in order to expose object text data for labelling to show.
I converted the 3D locust points to Stake Objects the cmt: field and its contents are lost. The convert to state object drop down doesn't appear to have any selection or combination to carry over to see empty field and its contents. Image is QGIS and VW fields for the data.
Has anyone resolved this?
Output fields are only these:
Stake #:
segment type:
segment length:3DlocustoStakequestion.thumb.JPG.9d4e31d1684f71d3f02a759b33d963fd.JPG
segment angle:
segment radius:
egment sweesz
segment rise:
clockmode:
polyline ID:
tag:
