Cristiano Alves Posted December 15, 2024 Share Posted December 15, 2024 Hi everyone, I’m experiencing a strange issue with object visualization in Vectorworks 2025. Yesterday, the last thing I did was save my project, and everything was working perfectly fine. However, today, only parts of the objects are being displayed. Here’s what’s happening: I can only see the objects properly in Top/Plan view. When switching to Shaded or Wireframe, only certain parts of the objects are visible. I haven’t changed any settings related to visualization or rendering. All layers and classes are set to visible. I can’t figure out why this is happening. Interestingly, if I copy everything and paste it into a blank project, the objects display normally in all views. Does anyone know what might be causing this? Any help would be greatly appreciated! Thank you! Quote Link to comment
JBenghiat Posted December 15, 2024 Share Posted December 15, 2024 Do you have the Clip Cube turned on? Quote Link to comment
Cristiano Alves Posted December 16, 2024 Author Share Posted December 16, 2024 9 hours ago, JBenghiat said: Do you have the Clip Cube turned on? I don't have the clip cube active, And now talking with a friend this happened with them too on VWX 25, on a MAC (I work on a PC windows) I can share my project here. Vizualization Problems.vwx Quote Link to comment
Jeff Prince Posted December 16, 2024 Share Posted December 16, 2024 31 minutes ago, Cristiano Alves said: I don't have the clip cube active, Actually, your clip cube is active and that is exactly the problem as seen the file you uploaded. Quote Link to comment
Cristiano Alves Posted December 16, 2024 Author Share Posted December 16, 2024 (edited) Probably I left this active because I tried your suggestion. I have the same problem too with the clip cube off or on. However.... I made the update now for 2.1 and this solve the problem! Thank you for your help Jeff Edited December 16, 2024 by Cristiano Alves Quote Link to comment
