GregG Posted December 12, 2024 Share Posted December 12, 2024 Enclosed screen grab is a clip cube view. This is frustrating.... Same four instances of the same symbol are stacked. Exact same X Y coordinates. Each symbol Z 10 ft 9 inches above another. Why is the fill different at the top instance of the symbol? Possible bug? Quote Link to comment
domer1322 Posted December 13, 2024 Share Posted December 13, 2024 I gave it a shot, but couldn't figure out the problem. This is not occurring for me on VW 2024. Are the stairs on different design layers and/or stories ? I assume you noticed the problem is not just the stairs, but the walls and elevator too. Did you make the whole assembly into a symbol, or are only the stairs a symbol ? Quote Link to comment
GregG Posted December 13, 2024 Author Share Posted December 13, 2024 Hi domer1322, The entire assembly is a symbol. Each stair/elevator core is on a different design layer. The stair is not a symbol. It's at a schematic stage so I used the stair tool built one. (BTW, the stir tool needs some development attention) The section viewport renders fine. Just the Clip Cube. Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted December 13, 2024 Vectorworks, Inc Employee Share Posted December 13, 2024 Hello, If you paste it into a new blank file does the same thing occur? Cheers, Peter Quote Link to comment
GregG Posted December 13, 2024 Author Share Posted December 13, 2024 In a blank file it works fine. Curious why would that make a difference? Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted December 14, 2024 Vectorworks, Inc Employee Share Posted December 14, 2024 It's a process of elimination, as this indicates that the problem is file related. Most likely an outlier object. Please read this Knowledgebase article about objects far from the Internal Origin, as that might be the cause. Cheers, Peter Quote Link to comment
GregG Posted December 14, 2024 Author Share Posted December 14, 2024 Thanks for looking into this. All of the objects in the file are reasonably close to the origin. All within 500 ft or 150 meters. It's a six level building The one oddity is the space objects floating above. These flat and are placed on a 0 elevation height level. The image below is all levels, classes set to be on and visible. Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted December 15, 2024 Vectorworks, Inc Employee Share Posted December 15, 2024 Just too be sure, if you go to Tools>Origin>Centre Drawing on Internal Origin can you send a screenshot and then click 'No' to exit the dialogue? As well, please let me know what units you're drawing in. Thanks, Peter Quote Link to comment
GregG Posted December 15, 2024 Author Share Posted December 15, 2024 screenshot from the file is enclosed In this file I am using US feet and inch example 1'-0" 1'-10 1/2" fractional inches This project is soon to go passed the schematic design phase. It would be nice to run as bug free as possible 🙂 Quote Link to comment
Vectorworks, Inc Employee Peter Neufeld. Posted December 15, 2024 Vectorworks, Inc Employee Share Posted December 15, 2024 Hmm that all looks fine. I'll DM you. Cheers, Peter Quote Link to comment
