Eyedropper tool symbol capable
B.Balemi
Hi All
One thing I feel I would benefit from is the ability to use the every good and much improved Eyedropper tool to be able to also pick up a symbol type and replace with another.
Also the abilty while we are on symbols, to thru the rescource browser when dragging and dropping a symbol into a drawing, be able to have an option to drag thru its folder or to make one so that it just doesent stay in top level.
This would keep library structure similar as you go thru drawings.
But wait there is more .
When replacing a symbol have the default appear in the symbol folder where that symbol is, or at least an option so that you are not scrolling all over the place.
this would be good when say you are replacing a 760 door with a 710 door or a 610 door blah blah. We usually have these all in the same folder.
this might not be necessary if the Eyedropper worked for symbols and had a couple of options to do the above.
Dont know if this would wreck havoc with workgroup referencing tho.
Cheeers Brendan
[ 05-17-2005, 06:26 AM: Message edited by: B.Balemi ]
1 answer to this question
