We often have to install staircases in our drawings which have stairs on the turn, i.e. say three stairs which lead the staircase around a 90deg turn. There are building regulations attached to these which make it difficult to do manually and the vw stair tool is not capable of doing this. for example, the angles stairs cannot be narrower than the other stairs in the flight, when measured in the centre of the tread, the tread depth cannot be less than that of the rest of the flight, and the narrow end of the tread cannot be less than 50mm. Is there anyway the stair tool can be adapted in future upgrades to enable us to draw turned staircases? We sometime have turns top and bottom if space is really tight.
gjefcoate
1 answer to this question
