Seeking script to create locus points at viewport bounding box
To reduce file sizes with graphical elements I often export an image of a viewport (or a group of elements), and then reimport that image file.
As VW’s image file export dialogue is idiosyncratic at best I normally place two locus points (at top left and bottom right in enclosed graphic). I set them out a mm or so (from the corners) to produce a slight oversize image (with a mm or so of white space) and avoid a pixelated edge, and then use the loci to snap to a precise window via the image export dialogue. The loci also provide a way to accurately measure viewport width, again to be able to produce a quality file via the image export dialogue. I’d be quite happy with a script that drew locus points, one at each corner.
Has anyone written or is there already a script to place locus points to define the bounding box of an object  in this case a view port?
In my screenshot of the viewport I have left the view port crop on as a visual guide as this defines the viewport bounding box.
Here you go.  This will work for all selected objects within the container you are in (layer, symbol edit, viewport crop or annotation, etc).
PROCEDURE BoundingBoxLocusPoints;
{*	Places locus points at the corners of the bounding box of all selected objects
	Developed by: Jesse Cogswell
	Date: 12/5/2024
	Revisions:
VAR
	parentHd:HANDLE;
	objArr:DYNARRAY[] OF HANDLE;
	numObj:INTEGER;
PROCEDURE AddToArray(h:HANDLE);
{Checks parent of given object and if matching current container, adds to global array}
	BEGIN
		IF(GetParent(h) = parentHd) THEN
			BEGIN
				numObj:=numObj + 1;
				ALLOCATE objArr[1..numObj];
				objArr[numObj]:=h;
			END;
	END;
PROCEDURE CreatePoints(arr:DYNARRAY[] OF HANDLE; num:INTEGER);
{Pulls bounding box for each object in given array and creates locus points}
	VAR
		i:INTEGER;
		A,B:POINT;
	BEGIN
		FOR i:=1 TO num DO
			BEGIN
				GetBBox(arr[i],A.x,A.y,B.x,B.y);
				Locus(A.x,A.y);
				Locus(B.x,A.y);
				Locus(A.x,B.y);
				Locus(B.x,B.y);
			END;
	END;
BEGIN
	numObj:=0;
	Locus(0,0);
	parentHd:=GetParent(LNewObj);
	DelObject(LNewObj);
	ForEachObject(AddToArray,(INSYMBOL & INVIEWPORT & (SEL)));
	IF(numObj > 0) THEN CreatePoints(objArr,numObj)
	ELSE SysBeep;
END;
Run(BoundingBoxLocusPoints);
	Date: 12/5/2024
	Revisions:
VAR
	parentHd:HANDLE;
	numObj:INTEGER;
	BEGIN
			BEGIN
				numObj:=numObj + 1;
				objArr[numObj]:=h;
			END;
	END;
	VAR
		i:INTEGER;
		A,B:POINT;
	BEGIN
		FOR i:=1 TO num DO
			BEGIN
				Locus(A.x,A.y);
				Locus(B.x,A.y);
				Locus(A.x,B.y);
				Locus(B.x,B.y);
			END;
	END;
BEGIN
	numObj:=0;
	Locus(0,0);
	DelObject(LNewObj);
	ELSE SysBeep;
END;
Thanks so much Jesse! that works perfectly
And thanks to Pat Stanford for how to change point number.
