Vectorworks 2025 Update 2.1 - Installer Problem
Hi @cberg,
Can you PM me the log from ~/Library/Logs? It should reveal what's blocking it. I'll actually make a note to have it report exactly what process it's finding in the future.
Thanks for linking the above thread @rDesign . That fix should be live, so I'm wondering if there's something else running.
Best regards,
Tim
Thanks for the @cberg . I was able to see the process blocking update ( Vectorworks 2025.app/Contents/Frameworks/Vectorworks Web Helper (GPU).app/Contents/MacOS/vectorworks_error_handler ). I'm asking around to see why this was stuck running.
For now, the updater was working as designed, but depending on what I find out, I can have it ignore that one or maybe provide a button that lets the user attempt to kill the processes it finds. And as mentioned, have it show what it found is running.
A reboot is a good remedy for now if this shows up again.
  • 4 weeks later...
Hallo zusammen,
Ich habe das gleiche Problem. Update SP 2.1 funktioniert nicht. Es erscheint nur ein leeres Popup-Fenster.
Schwach, vor allem wenn man die aktuelle Preiserhöhung der Service-Gebühren betrachtet. Ich frage mich wofür ich die noch bezahle. Aber wahrscheinlich ist es mal wieder Microsoft bzw. Windows an allem schuld. Ich kann es langsam nicht mehr hören.
  • 3 weeks later...
