Worksheet-Function or Script to retrieve the Name of the actual Worksheet?
Joshua is correct. And that was discussed when we fought this the last time.
In my opinion, that is too fragile to even use because it will return the name of the frontmost worksheet regardless of where the worksheet is in the stacking order or even if it is open if you Recalculate All.
Far safer to manually enter the name into a cell so you don't accidentally get the wrong information.
It could be interesting, but likely not really useful. Considering how many times I typically have to edit a script to get it to run properly, have a palette to type into instead wouldn't really save much time.
There are not very many things you can do in VW in just a single line or 2. Most useful things either need a loop of some kind or at least 5-10 lines of code. For that much work probably better to save as a script than to just enter one off.
$0.02
