I've found a small bug that doesn't affect anything and is easily rectified on the users end. Apologies if this has already been noted, but a quick search couldn't find it.
If you are editing an annotation for one viewport and then go directly into looking at a layer, when you go back to the sheet, the other viewports are still greyed out, despite the fact that you are no longer in annotation edit mode. Editing annotations of any other viewport and exiting again will fix it.
It should be noted that if one exports a PDF of the sheet while things are greyed out, it does export correctly.
WrightDE
I was able to recreate this in other/ new files.
2024-12-02 07-03-58.mkv
0 answers to this question
