Vectorworks Colors not accurate
TeeMuki
Hello,
is there a way to force colors to be the given values?
I try to set this color in the Attributes panel.
Picture 1.
When i give the correct color codes (RGB, CMYK or HEX), it shows the right color in Custom tab's small "preview window".
Picture 2.
But when i hit apply the color changes to something different?
I tried to use different color palettes, restart program and restart computer without any success.
I think the issue is not at my end... Or is there some setting that i'm missing?
How to fix this?
Currently running Vectorworks 2024 update 7.
Please help! 😄
Hmm, the problem actually still exists for our whole office.
When we open a new blank file in Vectorworks 2025 the colors are working, but when we open files that have started in Vectorworks 2024 the colors are not working.
This problem is now atleast on 5 different computers and licences...
Now i did open up a new blank file in Vectorworks 2024 and the colors are working, but on our projectfiles they are not working...
Below again one example
Blank file opened in Vwx 2024/2025 colors are correct
The same rectangles copied to our projectfiles (opened in Vwx 2024/2025) looks like this
What can cause this?
Is there a way to set up some colormodels (RGB/CMYK etc..) for the project, because it seems like this would be a simplified colormodel...
Does the import dwg maybe somehow change this colormodel to a simplified one?
Please help, this is actually a big problem for our office right now...
  • 4 weeks later...
16 hours ago, Katarina Ollikainen said:
@TeeMuki, Hello, can you please send me some sample files where we can see this difference? The engineers are looking at this issue but couldn't reproduce it, so it would be great with the file you're showing here.
Thanks.
Thank you for your fast response. I'll share the files with you via PM.
