Gal Posted November 21, 2024 Share Posted November 21, 2024 Hi Everyone, is that make sense? How can I make it work? Quote Link to comment
Pat Stanford Posted November 21, 2024 Share Posted November 21, 2024 I don't think IF is a valid Data Tag function value. You either have to use the Trinary function or use a worksheet if. Quote This is a perfect case for the Data Tag version of If/Then, also referred to the trinary operator. Put the result if true before an @ sign and the result if false after a colon (:) and put the test value in the middle. So something like: 'OBS'@#WinDoor 6.0#.#Opaque Glass#:'' So in your case: #∆X#@#∆X#>#∆Y#:#∆Y# Be careful because any extra spaces can impact the operation. Alternatively you could use a Worksheet IF, but I am not certain what you would need to get the ∆X and ∆Y values into the the worksheet format. #WS_IF(condition, Value if True, Value if False)# But you can not use the Data Tag hashtag surrounded format inside the WS function. It has to be pure worksheet definition. HTH 2 Quote Link to comment
Gal Posted November 21, 2024 Author Share Posted November 21, 2024 Oh, thanks so much! Is that a vectorscrip phrasing? Quote Link to comment
Pat Stanford Posted November 21, 2024 Share Posted November 21, 2024 No Vectorscript involved. The # (Hashtag) version are pure Data Tag. The #WS_ # version is a Data Tag function that executes Worksheet functions (as if they were in a database row) inside a data tag. Quote Link to comment
