Volumetric Rendering and Glow parameter
C. Andrew Dunning
Greetings!
3 features that are really needed are:
1) Volumetric rendering / atmospheric lighting effects.
2) A "glow" parameter for objects. Especially needed for creating realistic flourescent and neon tubes, as well as rope light.
3) A "Like" command. Explanation: When in the OI box or a tool-bar value box, the user would hit a hot key (such as "="). VW would then let the user use either the ruler tool or the protractor tool to measure a value from pre-existing drawing geometry. That value would then end up in the OI or tool-bar space. No more having to write things down...
Regards -
C. Andrew Dunning
Landru Design
www.landrudesign.com
4 answers to this question
1)Try Copy&Paste of parametric values
2) For Glo effects try using a semi-transparent phong or plastic lens based on a White Texture or any other color & pattern.
keeping in mind: "Becareful of what you wish for" . Every new PIO adds complexity and potential conflicts to the exist structure.
C&P is an OS API. All OS capabilities should be mandatory for VW. Less is more when it comes to code bloat.
Also, have you checked out some of the additional Vectorscript procedures available online ?
> 1)Try Copy&Paste of parametric values <
That is currently what I do. It just seems to be a pretty convoluted process for software that has some other-wise "productivity-encouraging" features.
> Also, have you checked out some of the additional Vectorscript procedures available online ? <
Yes. I'm a bit of a junkie for such things.
> 2) For Glo effects try using a semi-transparent phong or plastic lens based on a White Texture or any other color & pattern. <
Thanks for the hint - though I'd already given that a try. It makes the object glow, but doesn't even come close to acting like a light source.
