jpkna Posted November 14, 2024 Share Posted November 14, 2024 (edited) When manually creating door schedules we always use a standard UK door sizes and structural openings. The desired outcome is: Door leaf size = 926x2040mm Structural opening = 1010x2100mm I have my door styles set to Leaf Size and have set the standard leaf size correctly, however there doesn't appear to be a way to get the correct structural opening size if the leaf size is correct. I am using the following dimensions: width: 7 shim gap + 35 jamb + 926 leaf + 35 jamb + 7 shim gap = 1010mm width. this is perfect. height: 2040 leaf + 35 jamb + 7 shim gap = 2082mm. this is not perfect and i want it to be 2100mm Is there a way to increase the gap under the leaf by 18mm to raise the leaf and correctly display the structural opening? Or can you increase just the top jamb dimensions? Edited November 14, 2024 by jpkna Quote Link to comment
Tom W. Posted November 14, 2024 Share Posted November 14, 2024 13 minutes ago, jpkna said: When manually creating door schedules we always use a standard UK door sizes and structural openings. The desired outcome is: Door leaf size = 926x2040mm Structural opening = 1010x2100mm I have my door styles set to Leaf Size and have set the standard leaf size correctly, however there doesn't appear to be a way to get the correct structural opening size if the leaf size is correct. I am using the following dimensions: width: 7 shim gap + 35 jamb + 926 leaf + 35 jamb + 7 shim gap = 1010mm width. this is perfect. height: 2040 leaf + 35 jamb + 7 shim gap = 2082mm. this is not perfect and i want it to be 2100mm Is there a way to increase the gap under the leaf by 18mm to raise the leaf and correctly display the structural opening? Or can you increase just the top jamb dimensions? Are you using VW2021 as per your signature? In VW2024 a 'Gap Below Leaf' parameter was added which will achieve exactly what you want. Quote Link to comment
jpkna Posted November 14, 2024 Author Share Posted November 14, 2024 I am on VW2021 unfortunately - but we are upgrading hardware to support VW2025 soon. Glad to know it is a feature we can look forward to, but I suppose that means there is no way to achieve it in VW2021? Quote Link to comment
Tom W. Posted November 14, 2024 Share Posted November 14, 2024 19 minutes ago, jpkna said: but I suppose that means there is no way to achieve it in VW2021? I think you could probably do it by including an 18mm thick Threshold + putting it in an invisible class... You can set the Threshold to just be under the leaf + if it's invisible it effectively becomes a gap under the leaf. Are these internal doors? Quote Link to comment
