vectorscript to read the viewport view and write that data to the viewport title
Ben3B
With thanks to Raymond and Pat!
Select a viewport and run the script.
This is just a test to see if it was possible.  (And to learn how it works)
I assumed you would want to add to a title that was already there. Let us know how you would like it formatted.  It would probably be a good idea to be able to select and rename more than one viewport at a time also :-).
It was interesting to figure out how viewports set their views.  I've never had to learn about the viewmatrix before.
viewport views.vwx
Thank you so much , it works well!!!
attached is the file with the same script with french view name viewport views US_FR.vwx
Do you know if its possible to do the same with datatag? by the way I could insert it in the title block style , to automate it ;)
and YES below is a good idea :)
Edited by Ben3B
I've found a problem with the script
if the first viewport isn't at top plan it name it top plan as you can see below
I did with french and us version ;)
I started from 1 duplicate to 2 and 2 to 3 (change the view)
and the duplicate the 3 first 1-2-3 to 4-5-6 change to wireframe the duplicated 5 to 7 change to top plan and then duplicated 1-2-3-4-5-6-7 to 8-9-10-11-12-13-14
I mean that's why 1-4-8and 11 are wrong because there all are from 1 ;) pb viwport rename.vwx
Edited by Ben3B
Data tags can use worksheet scripts. So a minimal modification to the first script as long as you are using the Data Tag to tag the viewport.
Replace the FSActLayer at the top with WSScript_GetObject
Replace the SetObjectVariableString at the bottom with WS_Script_SetResStr
Then assuming the script is named Script in the data tag use:
#WS_RunScript('Script')#
