Ben3B Posted November 13, 2024 Share Posted November 13, 2024 Is a way to automatically put the name of the view (such as top left right isometric...) in the title bloc ? i cant find "view" in the field when i edit title block I tried to create a data tag to put it inside the title block , but I cant find the good field I tried to make viewport style one by camera view but can't report the viewport style name ... Any idea ? thanks Quote Link to comment
michaelk Posted November 13, 2024 Share Posted November 13, 2024 Do you mean the title block of the sheet layer or the drawing label of the viewport? Quote Link to comment
Ben3B Posted November 13, 2024 Author Share Posted November 13, 2024 22 minutes ago, michaelk said: Do you mean the title block of the sheet layer or the drawing label of the viewport? I mean the drawing label of the viewport (sorry but I'm on a french version and translation isn't easy ;) ) Quote Link to comment
michaelk Posted November 13, 2024 Share Posted November 13, 2024 That's what I thought 🙂. The Viewport view isn't saved in a record attached to the viewport, it's an object variable. It should be possible to use a vectorscript to read the viewport view and write that data to the viewport title. That will get picked up by the drawing label. 1 Quote Link to comment
Ben3B Posted November 14, 2024 Author Share Posted November 14, 2024 (edited) 10 hours ago, michaelk said: It should be possible to use a vectorscript to read the viewport view and write that data to the viewport title. That will get picked up by the drawing label. Yes that's what i thought, but vectorscript is a bit more complicated than datatags ... I ask in the vectorscript section :) https://forum.vectorworks.net/index.php?/topic/121060-vectorscript-to-read-the-viewport-view-and-write-that-data-to-the-viewport-title/ Edited November 14, 2024 by Ben3B Quote Link to comment
