NDI stream onto an object in Vision
Hi,
working in Vision.
I've imported an extruded object from Spotlight via MVR. I select NDI stream as a video source. I don't get the whole picture from the stream. I suspect, that what I see is just one pixel of streaming video covering the whole object. If I create an object directly in Vision, stream works just fine. What am I missing? Is it the way I create object in Spotlight? Is there any setting for an object later in Vision?
Thank you.
