Delmer Posted March 28, 2005 Share Posted March 28, 2005 It doesn't have to be a lassoo, but to be able to make a fence or marquee by polygon would sure be great. Quote Link to comment
0 B.Balemi Posted March 30, 2005 Share Posted March 30, 2005 Delmer Have you held down the alt key while you use the lasso. Same applies for the marquee All you have to do is hit or pass over the object once not even circle it and it selects it . Its very quick. I hope this helps. Regards Brendan [ 03-30-2005, 04:03 AM: Message edited by: B.Balemi ] Quote Link to comment
0 Delmer Posted March 31, 2005 Author Share Posted March 31, 2005 That is useful. I just wish I could do the same with the 2D reshape tool. I constantly use it for stretching multiple objects with varying lengths. Quote Link to comment
0 B.Balemi Posted April 4, 2005 Share Posted April 4, 2005 I Agree multiple node delete would be handy at times around the non orthoganal marquee area. Also context sensitive operation. When you have a rectangle selected it prompts you if you hit the 2d edit tool whether or not you want the rect to converted to a poly so as to manipulate. Brendan Quote Link to comment
0 Delmer Posted April 5, 2005 Author Share Posted April 5, 2005 Good cues could be taken from Adobe here (again). The marquee could not only be polygonal but holding shift or alt/opt could add and subtract selection areas. Quote Link to comment
0 B.Balemi Posted April 8, 2005 Share Posted April 8, 2005 Also the ability to duplicate or mirrror multiple seleted nodes along an axis. And the abilty thru the OIP to on and off hidden node points possibly. Brendan Quote Link to comment
Delmer
5 answers to this question
