Delmer
2D reshape tool non-orthagonal marquee
It doesn't have to be a lassoo, but to be able to make a fence or marquee by polygon would sure be great.
5 answers to this question
Delmer
Have you held down the alt key while you use the lasso.
Same applies for the marquee
All you have to do is hit or pass over the object once not even circle it and it selects it .
Its very quick.
I hope this helps.
Regards Brendan
[ 03-30-2005, 04:03 AM: Message edited by: B.Balemi ]
That is useful. I just wish I could do the same with the 2D reshape tool. I constantly use it for stretching multiple objects with varying lengths.
I Agree multiple node delete would be handy at times around the non orthoganal marquee area.
Also context sensitive operation.
When you have a rectangle selected it prompts you if you hit the 2d edit tool whether or not you want the rect to converted to a poly so as to manipulate.
Brendan
Good cues could be taken from Adobe here (again). The marquee could not only be polygonal but holding shift or alt/opt could add and subtract selection areas.
Also the ability to duplicate or mirrror multiple seleted nodes along an axis.
And the abilty thru the OIP to on and off hidden node points possibly.
Brendan
