Hi Everyone,
I've been using vectorworks for a long time now and inserting windows into masonry veneer opening is still mind boggling to me.  I've gotten the window to look how I want it in 3d view and in elevation but in plan view the masonry overlaps the trim (which it does not do in elevation or in 3d). How do I correct this?  All the examples I've downloaded from the vectorworks site eliminate the trim and just increase the frame size but that is not the solution i'm looking for.  I've attached 3d view of the exterior, interior and then the plan view as currently is.  I've also attached a marked up plan view using annotations of what I would like the top plan result to be.  Does anyone have any suggestions or a workflow that produces a clean result?
Thank you,
Derek
