Y axis doesn't works with XformDMX
That is definitely odd! Movement is generally easier to work with when compared to rotation as rotation only supports one axis at a time. And, you are clearly getting DMX into Showcase and have things patched correctly if the Z and X axes are working as expected.
May I ask what object you have applied this record to? And, can I also have you confirm that you do indeed have a non-zero value in the Delta Y field of the record?
20 minutes ago, Rosa Prod said:
Thanks for your answer @bbudzon
In fact Y axis is Z axis in showcase or Vision.
This record was attached to a stair symbol and in fact i didn’t patch correctly the dmx value. I've forgotten the fine channels.
Now everything works well !!
Thanks
I'm glad you were able to get it to work! And, I know the "transition" from Vision into Showcase can be a little confusing as Vision was always in inches and Y was up. We hope that Showcase being in VW will sort of "set the record straight" and be less confusing in the long run to our users.
